Hi Everyone,
I am new to this forum. I have an issue with my monitor 2400. It works perfectly until it reaches the thermostat temperature. Once the temperature goes below the thermostat setting the unit tries to start the burn light goes on for a second and then I get a e13 error. I had the unit service ( almost everything replaced , I can share the receipt if need be) and the problem went away for a week. They did not replace the flamerod so I did that today.
The problem still persists. The only way to get the unit to work is to turn it off and on again. When it does fire up again there is a lot of Grayish smoke coming out of the vent.
Anything else I can try. I live on a island and it not that convenient to get it serviced. Plus I do not want to take it back to the people that did not correct the problem in the first place.
Thank,
mike - Rhode Island
Thank,
mike - Rhode Island
