Monitor 22 not putting out enough heat
  • msearcher
    • Mar 2011
    • 125
    Blue ring is showing but the burn ring never glows orange. I have swapped our the pump controller and pump - no change.
    the combustion motor sevens to put out plenty of air.
    looking for ideas, I might swap out the fuel line and see if that helps, I will say that there was dirty kerosene used in the internal tank, I replaced the internal sump and cleaned the carburetor and filter and currently running off an external tank.
    thanks in advance for any ideas, I know the mat and ring are ok.
    • 755
    When was the last time you installed a new mat and ring?
    • msearcher
      • Mar 2011
      • 125
      When was the last time you installed a new amt and ring?
      I did service this heater last year with new mat and ring and will check them shortly. Thanks for your reply.
