Gf3800 heater display problem
  • rrob311
    • Nov 2014
    • 86
    My gf3800 display was blank this morning and temp button was not responding. I unplugged unit and worked ok when plugged back in. Now it's showing part of display. Is display or board failure common on these? I would like to get this repaired.
    • 752
    I would check the wire connections to be sure they are tight. Both to the indicator board and to the main board. No lint or dust on things.
    If the board is bad, it is the same board as M2400, part number 6716. EBAY or Hickory Home and Gardens for parts.
      • 752
      rrob311, Did you get your stove going? Keep us posted on your progress.
