Toyo tip of the century
    • 758
    Put anti-seize on exhaust pipes and flue pipes O Rings. This will allow you to remove them in the future without putting too much force on the connections.
    Laser 56 heater with frozen exhaust pipes can get expensive. Too much force can break the fitting on the back of the blower assy. If broken, the whole blower assembly should be replaced. You can't afford to mess around with CO.
    Stay warm
