Laser 30 air flow from rear fan, over heat exchanger to room
  • TechEditor
    • Dec 2014
    • 60
    Maybe a dumb question but I installed my old Laser 30 model A in my old shop after a complete rebuild. It doesn't seem to distribute heat as well as an old Kero-Sun Radiant 36 with a Ker-Blo fan on top. It is only 9600 vs 15000. So I wondered what would happen if I removed the front panel and the internal plate that has the over temp sensor to allow the rear fan to blow straight thru like a Laser 73/730. I see the chamber heat reflector covers about 1/2 of the fan. So it looks like the fan air must blow thru the heat exchanger, then bounce off the plate and be forced down around the heat chamber and then turn and exit the case thu the lower louvers.
    Is it necessary to have the air go around the heat chamber? Is it for cooling the heat chamber? Or is it just their original design from 1999 that has been superceeded by a straignt thru design?
    With the front cover off and the plate removed, there is a large quantity of hot air blown into the shop (at least in a 5 minute test). Anyboy ever run one with the cover off? And is there any downsides if I replace the over temp sensor some how in roughly the same place? Cut away a section of the reflector directly behind the heat tower to allow the fan to blow directly on it. And install some kind of vented front cover, (with something like hardware cloth or the like).
