Had this question posted in the Toyostove thread, but I thought I might get more (any) responses here.
Toyotomi Laser 30, "A" model. The Heat Chamber Assy, #19 has become loose and rotates and leaks exhaust during start up until it is up to temperature and the heat expansion tightens up the assy. This unit was purchased used with few hrs on it. I have purchased the replacement gaskets, Joint Gasket #16, Upper Gasket #18, and Lower Gasket # 21. I have the Heat Exchanger off #36, but I am stumped on what to do next. Do the screws on the top of the Heat Chamber Cover #17 have to come off to remove the Heat Chamber Assy, #19? I tried several and they seem to be rusted in so either heat is used or you just destroy them to get them out. I need disassembly instructions or a downloadable Factory Service Manual to accomplish this. All I have been able to obtain is the Installation / Maintenance Manual. Below is the state it is in now.
Background is an ATV mechanic for 25 yrs.
