Laser 730 over firing
  • Nycpa1
    • Feb 2026
    • 6
    #16
    Hello all,
    Sorry I haven’t replied sooner.
    The 731 pretty much runs great but I can’t stand the noise. I made a bunch of calls and inquiries last season, and the consensus is they are noisy. I spoke to a few dealers up in Maine recently, and they said the newer Toyo’s are noisy and people are complaining.
    If the unit is on high for a few minutes, it does have a slight glow between the burn chamber and the heat exchanger connection. I asked about that as well and the response I received was it is normal. I was told to refer to the manual. I read it already and know it says a slight glow is normal. Even rural enterprise sent out a bulletin saying a slight glow can or might be abnormal so this being my first Toyotomi I don’t have any other experience. I brought it up to my installer, he said both of his do the same when on high.
    As far as the noise, it’s different at times, and i started to run it in power saver so it almost never cycles off.
    The replacement heat exchanger is not as bad as the original but it still is annoying.
    One thing I’d like to add, is the welds are horrible on the heat exchangers. The replacement looks like someone gave a kid who wanted to play with a welding machine made the welds. It only had two snotty tacks, I belion the outlet side. Does it have anything to do with the noise? I think so being in a mechanical field myself.
    Anyone else have any new experience or issues?
    I’ll keep an eye on the forum.
    Thanks, Nick
    • Nycpa1
      • Feb 2026
      • 6
      #17
      Nycpa1,
      Can you give us an up date on your Laser 731 over firing issue?
      Thank you,
      Hi Tom, sorry the heater was out of my mind during the summer. I’m away for a few days, I’ll be back home by Friday. I’ll send you the serial and date numbers.
      Have you came across any other units having similar problems?
      Nick
        • 758
        #18
        As far as the some Laser 730 series heaters experiencing a cracking noise while running, yes this is happening. NO, it is not normal. Despite the statements from your dealer and the REE site, the cracking noise you are hearing is not normal at all.
        This cracking is coming from the heat exchanger getting very hot and the metal moving around due to the heat. As you stated the cracking also happens when the stove steps down to Med or Low. The metal is moving again due to the heat going away.
        The most likely cause for this noise is the stove is over firing. This over firing can be seen at the top of the heat element and the top on the bottom chamber of the heat exchanger.
        This cracking of the heat exchanger could happen on Laser 73 heaters as well. When it did happen on a L73 it was very evident that something was very wrong. Laser 73 heaters never made a cracking noise unless something was very wrong. Just a look at the flame on an L 73 that was making a cracking noise, made you aware that the flame was very high.
        Just as a reference to my service work on Laser 73 heaters, I may have done over 3000 of them in the last 20 years. In that time, if I had an over firing L73, which was very seldom, the fix would be a new fuel pump.
        Now days with Laser 730, 731, 732 series heaters, an over firing heater is an almost guaranteed issue. I have done two this week. Some can be cured by reducing the fuel flow by 10 percent. This should be done only after checking the burner pot for a warp or a lifted mat, blocked exhaust or heat exchanger. The procedure for reducing the fuel flow is spelled out in the service manual under the title High Altitude Setting Mode.
        I am only giving this information out because Toyotomi has stated in their manual a procedure to” adjust the fuel pump”. The procedure stated in the manual to adjust the pump has you adjust each pump level separately and is very complicated. Adjusting the pump to High Altitude does everything in one step by reducing all pump modes at the same time by 10 percent. This fix has worked in almost every occasion.
        • Nycpa1
          • Feb 2026
          • 6
          #19
          Thank you. I have a different tech coming over this weekend. We are gonna open it up and take a look.
          What is strange to me is that the flame is nice and level and blue. I thought if it were overfiring, the flame would be yellow and uneven.
          I thought about reducing the fuel, and the rep from Toyo told me no to. This new tech has all the stuff we need to rebuild it.
          Have you installed any of the 733’s ? The only difference I see is it now has voice control over Bluetooth which I would never use, but I’m wondering if the fuel rate issue has been resolved.
          Thanks for your info, I will let you know what happens.
          Nick.
            • 758
            #20
            It does not hurt to change the pump to High Altitude setting to see if the flame is reduced. You can change it right back if you don't like the results. The procedure is spelled out in the Service Manual. Each different dash number model has a different key stroke sequence.
            The likelihood of two new heat exchangers having the same problem is very remote. I see many more burner pots warped than heat exchangers cracked.
            You will need to remove the pot and chamber and flip it upside down to remove the burner insulating pad. Now you can see the bottom of the burner pot. Run your finger over the bottom. It should be smooth over the whole bottom. Any raised areas are a problem. Even the slightest rise in the smooth bottom is a reason to replace the pot. This is where I would start.
            • Nycpa1
              • Feb 2026
              • 6
              #21
              Thank you. I will try it and see what happens. I am there on the weekends.
              Nick
              • Nycpa1
                • Feb 2026
                • 6
                #22
                Tom,
                Here is an update.
                The tech came out to me. We ran it through its cycles a few times. According to him, the flame is perfect on all modes, he didn’t recommend lowering the fuel, I kinda disagreed with him.
                It does make some expansion sounds starting and changing modes and at shutdown.
                He spent an hour there and said basically the newer ones are noisier, and that he’s had a few warranty calls and toyotomi tells him exactly the same. They are not supposed to cycle and should stay in med or low the whole season. He disagrees with that.
                The small amount of glowing on high is normal according to the tech as well.
                I have lowered the fuel, it still makes noise, the other issue it it never comes up to temp even with the temps outside in the 40’s, so I call B/S to toyotomi’s tech telling me the heater is oversized.
                I’ll let it run for the season, and figure out if I want to rebuild the monitor 2400 or go to a Rinnai propane version.
                I’ll follow the discussion and give you any updates.
                Thanks,
                Nick
                  • 758
                  #23
                  Nick, I sent you a Private Message.
                  • dntreecareinc
                    • Oct 2026
                    • 15
                    #24
                    Thanks for the update, Nick — reassuring that the tech found the flame and the small glow normal, even if the noise is still annoying. Since it never quite comes up to temp even in the 40s, keeping a quick note of the set temp versus the actual room temp over the next few cold snaps should make it clearer whether it is really falling behind or just running longer with the lower fuel setting.
