Nortron Furnace
  • sdavidson
    • Aug 2005
    • 20
    Nortron Furnace
    Hey guys, I got a norton furnace, and I got a wicked problem, the fan will not turn off ? it doesn't matter what I set it too, there is a 2 wire control going to the furnance, one of course connecte to Power (R) and the other connected to Heat (W1) but I can't get it to auto shut off when it hits any temp? I think it may be the relay's but I wanted a second opinion ?
    Thanks
    Pull the front service access cover off your furnace and you should find a wiring schematic glued on the inside of the cover.
    If you have a two wire thermostat it is most likely only controling the burner and the fan is being separately controlled by a heat sensing thermostate in the plenum.
    • lonestarheir
      • Jul 2005
      • 137
      You could have a fan relay that is stuck in the closed position
      Brandon
      Brandon
      • sdavidson
        • Aug 2005
        • 20
        Ahh, ok I will go home and see that on my lunch, I have changed the filter.. I always do...
        • sdavidson
          • Aug 2005
          • 20
          ok, I took a look on cover, and it is gone, i guess whom ever owned it removed it for some reason.. I will give you a web link, hopefully somone can help me out.. remember the reason why I am asking is that my 2 wire furnace, the fan will not shut off.. when it is on.. I turned the breaker off for now, since it runs constant...
          Thanks
          This the link for the pic
          I noticed that the blue wireing coming off of the large transformer in the middle is not connected...
          thanks again
          • Mike3
            • Nov 2004
            • 13
            If you have a standard fan control (not a fan timer board) the off temp may be set to low, causing the ambient heat to close switch.
              i have examined the photo and I think i will be able to make you a schematic for this unit but I need to know what the red writing on the housing beside the second relay says.
              Check the label on the transformer..That appears to be a 110v/220v primary transformer. The red wire is used for 220v primary and the unused blue wire would be used in place of the red for a 110v primary voltage supply.
              • 2story
                • Aug 2005
                • 17
                what is the thermostat set on?
                • sdavidson
                  • Aug 2005
                  • 20
                  I will go and get that info tonight...
                  thanks
                  • sdavidson
                    • Aug 2005
                    • 20
                    The red sticker says " 240 VOLT RELAY "
                    • sdavidson
                      • Aug 2005
                      • 20
                      So with all that what you think I should be looking at ? I have to turn the furnace off via the breakers, cause it never shuts off ?
                      • imeduc
                        • 330
                        Have you checked the fan relay??? Does it open and close ok?????
                        ED
                        • lonestarheir
                          • Jul 2005
                          • 137
                          okay - easy test, there are two wires on one end of the fan relay, and three or four on the other end. Take one of the two wires off "Carefully - you are surrounded by line voltage" if the fan stops, you have a bad fan relay. If it does go off then you may have a problem in the fan switch at the unit. That is assuming that there is still a little switch to change the fan from auto to on. More than likely one of the two is your problem
                          Brandon
                          Brandon
                          • sdavidson
                            • Aug 2005
                            • 20
                            buy your diagram, I see the fan relay, so do I have 2 of them ? since I see two there, it seems obvious, but since I am not a furnace guy I have to ask, and the two wires, you mean at the bottom of each relay?
                            p.s I want to thank you for all your help... it is nice to see some guys out there still help you out...
                            • sdavidson
                              • Aug 2005
                              • 20
                              #15
                              I got one other question? if I can be so bold, is there a fast way to test each element ?
