I have hot water radiators. A WeilMclain CGM-4 boiler with a B&G LR20BF pump. I recently installed a Ritetemp 8022c thermostat to replace the ancient Honeywell round one that was there when I moved in. However, I am now experiencing really big temperature swings. When the Ritetemp is set to 68, the house temperature spikes as high as 72, and drifts way back down again. I have tried reducing the "swing" setting on the thermostat, but it hasn't helped. Since its a digital, I can't change the anticipator setting either.
One thing I have noticed is that with the old thermostat, the radiators got warm, but never really too hot to touch. Now they get much hotter. I think this is related to the fact that with the old thermostat, the pump ran constantly, even when the burners on the boiler were off. With the Ritetemp, the pump only runs when the burners are on. Is there a way to wire things so that the pump runs constantly again? There are 2 wires from the boiler to the thermostat, at the boiler they are labeled R and G.
