Hello - hope you can help. Carrier has no customer support - lame! I have a Carrier 58RAV induced-combustion downflow furnace. It is controlled by a Honeywell Chronotherm III thermostat (T8600C). This is apparently a "pwer-stealing" thermostat. Here are my issues:
1. During a heating cycle, after the burners have shut off but the fan is still running, I get a "-AC" code on the thermostat, which, I am told, indicates a loss of AC power to the thermostat. Once the heating cycle is over (fan shuts off) the normal display of the current temperature is shown.
2. In the morning, I have noticed that the furnace is cycling A LOT. It will come on, run for maybe 5-6 minutes, then shut off. It then kicks on again after about a minute or so and the whole thing repeats over and over. I know this thermostat has "adaptive" technology where it tries to ramp up the temperature prior to the set time. The "wake" time we have set is 4:30AM. This is still occurring at 6:30AM. The thermostat reads 70, which is the set point. It is pretty cool outside the past few mornings (under 40 degrees F), but I just don't know if this is normal behavior or not.
Thanks for your help!
CarrierDude
CarrierDude
