We discovered swelling bricks around the base of our chimney in the basement and called someone out to give us an estimate and possible cause. Our furnace was replaced a year ago and rerouted directly outside through the wall, rather than through the chimney. We were told at the time a new liner in the chimney wasn't really possible because of the age and size of the flue, so he went direct. Now, we're getting swelling bricks at the base of the chimney and it was determined that the vent on the water heater (vented through the chimney) is not the correct size for the BTU's being used. As a result, the water vapors aren't getting enough suction to pull them all the way up and are falling back down, causing moisture at the bottom. Also, he found deposits on the inside of the HWH vent and put a lighter to the edge of the vent. There was no pull on the flame toward the center of the vent, so he said we're not getting the CO2 vented properly.
His recommendation is to put a liner (HomeSaver Ultra Pro) in the flue and change the size of the vent on the HWH. His charge for this is around $2000. This would also include the repair to the mortar and brick and a raincap on the top.
He also told us the furnace guy lied about the liner just so he can route the furnace direct, which in the end costs more money.
Does this sound legitimate to everyone? He's scheduled to come out Sat. to do the work.
Thanks for your help.
