...being new to the forum, i will apologize in advance for requesting duplicate info/direction on this topic if it has indeed previously been posted...i have actually read (and not once seen this topic?) many, but not all threads/posts (on the monitors) as of yet!
anywho, i have a very specific curiosity 'bout something...why, since the 40, 41, 441, and 'newer' 2400 models all use basically the same 'hard' parts for operation, (sans the control board for the 2400) are the 441 & 2400 (most recent models) not comparable in output specs?...it would seem reasonable if they might be off by a couple hundred to maybe a thousand btu units, but not by multiple thousands?...these are basically one and the same (hardparts wise!), so they should perform relatively the same in my opinion???...obviously, the control system may be a little different, with different programming, fuel trims, etc; but that still should not affect the numbers in the way that i am seeing? more fuel might mean higher consumption numbers and obvious higher output numbers, but that is not really the issue...there are values for the two units that are VERY similar in heat rating btu AND consumption values, BUT the heat output btus are not the same @ all, in fact, very different and several thousand btus apart from one another?
...the only 'logical' explanation for this scenario i could determine was possibly that Monitor basically 'overrated' these (early generation) units output values from the getgo & rolled w/ those numbers for all those years; maybe until the testing & certifications became better, more precise, or more regulated/enforced by EPA or whomever, like nowadays?
the reason i think this, is because basically: i will buy the fact that when i see a 40k rated heater unit, i ass-u-me that it is pushing 40k, just like its rated to do...(i also realize the AFUE taking in the 'non-condensing' water situation lowering the rating a little bit, but honestly this 'factor' does not really enter my mind, because it basically affects ANY type of 'combustible type' heater out there, anyway!
...basically apples to apples, a 40k unit, is a 40k unit, is a 40k unit to me when i am searching for the right machine to do the job!...what i DONT expect to find is literally two identical 40k models pushing very different outputs from virtually the same identical inputs?...
i realize i'm 'long-winded' & have probably now managed to confuse more people than actually 'enlightened' to this curious situation, so if i made it complex...here are the ratings so u can see 4 yourself my numbers in question!
M441
Heat Rating High: 43,000 BTU/hour
H.Medium: 33,900 BTU/hour
LMedium: 21,000 BTU/hour
Low: 16,200 BTU/hour
Heater Output High: 40,000 BTU/hour
H.Medium: 31,500 BTU/hour
L Medium: 19,500 BTU/hour
Low: 15,000 BTU/hour
M2400
Heat Rating High : 43,000 BTU/hour
H.Medium : 32,000 BTU/hour
L.Medium : 24,600 BTU/hour
Heater Output High : 37,200 BTU/hour
H.Medium : 26,900 BTU/hour
L.Medium : 20,700 BTU/hour
Low : 13,600 BTU/hour
...i also realize that this stuff doesnt really mean a whole lot in the 'big picture', but thought that maybe someone had some 'inside' knowledge, or maybe a better insight as to why the values are so far apart...as usually newer is 'better' (in theory, anyway!) and i dont feel the new specs are much better than the old; in fact, they're actually worse & unexplained...in my opinion, it should not be so & has no logical reasoning behind it... (but i am NOT an engineer, by any means!)
Thanx for any insight!
![Mad](https://homerepairforum.com/core/images/smilies/mad.png)
![Roll Eyes (Sarcastic)](https://homerepairforum.com/core/images/smilies/rolleyes.png)
![EEK!](https://homerepairforum.com/core/images/smilies/eek.png)
M441
M2400
![Big Grin](https://homerepairforum.com/core/images/smilies/biggrin.png)
