monitor 441
thanks for the response.i will try tomorrow morning to get into the heater. i can not remember if the fuel sump has an incoming line and a line going out to the burner. if it has 2 lines i am assuming i disconnect both to remove the sump from the unit. in cleaning the sump is there anything i should be aware of .(so as not to break!) sorry but i am a novice at this ,and have not taken apart a sump before. to drain the sump do i undo the cover that holds the small filter? will this drain the whole sump? also, i do not have a parts breakdown/ schematic. can i download the repair manual from the first page of this thread? downloading can take me a while as i have dial up service for my computer. thomas
