My monitor 22 tries to start up but it does not light up and eventually fails with all burner lights flashing.
The igniter does not glow red (I can't see a light through the chamber window) but it does get warm to the touch after a few minutes.
The level pump screen was very dirty, I cleaned it with kerosene and rubbing alcohol and then used the prime switch to try to prime the system. The prime switch does not have any resistance, should it?
I hear a very faint fan when turning on the unit, so I assume the combustion fan is running but I can't tell for sure (it's almost in the background noise).
(a) is there a way to see if fuel makes to the combustion chamber?
(b) I never hear any pump going on or any ticking at all, should I hear it struggle to pump fuel into the chamber?
Any other thoughts?
Thank you!
Any other thoughts?
Thank you!
