Flame sensor for BS36
After 10 years of operation, my BS36 started shutting down after 25 seconds after startup. I keep it turned off except when I need hot water. I found out that meant the flame sensor wasn't working properly. I bridged the flame sensor cord on the PWB with a 1 meg resistor to bring the resistance down.
That lasted 4 years. Then the heater started shutting down after 25 seconds again. I tried bridging it with smaller resistors, but no luck. I finally bought a new detector from Nelson & Small.
I noticed the flame detector was a hollow plastic unit with a rubber plug in the end where the cord went in. I pried the plug out & remove the CdS cell with the wires attached. These cells go bad after a while; their operating point shifts. I replaced the CdS cell with one from Radio Shack that had similar characteristics. At the time, Radio Shack sold a package of 5 different cells, part number 276-1657. I used one that was the same size as the original. It has to be small to fit in the plastic tube. The detector I bought from Nelson & Small in Jun 2011 is still working, so I have not tried my repaired one out.
I found a notice from Hamamatsu Photonics, the original CdS cell, that they were no longer manufacturing CdS cells after Dec 2005 because of restriction of Cadmium products being imported into the EU. The original cell is a Hamamatsu S96-48-100. I have the spec sheet for this if you're interested.
NOTE: The new flame detector I bought had greater than 100 megOhm resistance when in the socket with the burner off. The resistance dropped to 60kOhm when the burner was on.
Alan
Have you ever removed the burner gun to look at the nozzle and electrodes? The reason I ask is the 20 second warning is not usually connected with the flame sensor. The two second warning is usually an electrical problem of some sort (ignition transformer, circuit board, flame sensor). The twenty second warning is usually some kind of fuel related problem, no fuel, pump, nozzle.
At the time this happened I did replace the nozzle & cleaned the electrodes & reset them according to the repair manual. The unit still shut down after 25 seconds with what seemed to be a healthy flame. I ran across Document 357.pdf from Rural Energy Enterprises which states "The 25 second warning light is tied to the flame sensor. In this case, if the flame sensor does not detect a light (flame) in the combustion chamber during the ignition cycle." The voltage across the new flame detector terminals measured 5.9Vdc at startup & went to 3.8Vdc when the burner lights & then gradually dropped to 2.8Vdc. The original detector voltage wasn't dropping low enough with a flame. The new detector I bought was seeing the same flame as the old detector, so it seemed that it was the detector, not the flame intensity.
Mistake: It's Document 347.pdf, not 357. It's no longer on REE's web site. They had a newer version which included the Oil Miser 148, but it's gone too. If you Google bs-36uff 25 second warning light, you will find 2 pdf's from Rural Energy Live Life Warm dealing with the 25 second warning light.
Has anyone had an occurrence of a Laser 730 or 731 over firing? The top of the heat chamber and the heat exchanger glow red on high when this occurs....
