Laser 73 repeat ee6 code
  • rrob311
    • Nov 2014
    • 86
    Hi I have a laser 73 in good shape that I keep getting code ee6 or ee code. Sometimes the filter will be clogged but other times it will shutoff where I don't hear the pump. I was thinking the flame rod could be acting up or the board? Any tips? I need a reliable heater.
    • 758
    You seem to have a fuel problem, as you say, "sometime the filter will be clogged". EE6 is a message you will get with a dirty filter or low fuel head pressure.
    • rrob311
      • Nov 2014
      • 86
      I took it out of service. I am pretty sure the sump is clogged on that too. I am in the process of retiring the quik tank I had feeding it.
      • makdju3
        • Feb 2026
        To troubleshoot further, you can use a morse code translator to decode any hidden messages!
