Longevity Question
  • Longevity Question
    I have a 2007 L73. It had a replacement Burner Pot & Burner Ring in 2014. In December it will be 19 yrs old. I was contemplating a rebuild this summer of a new Mat and Burner Ring. However after setting in on today's Toyotomi on-line class where it was said that the chimneys should be replaced about every 12 yrs or so due to internal corrosion leaking exhaust into the fresh air intake tube AND references to maybe thinking about replacing the unit vs rebuilding in the 12 - 15 yr range.
    So Hawkins, please chime in here with your recommendations. My L73 has not given me any problems, save for the Bee incident necessitating the pot and ring replacement, in 19 yrs., so it surely doesn't owe me anything.
    Greg
    Your L73 is worth rebuilding. Even if it is a little expensive, it is still worth the money. A new L730 is over $2500, where a rebuilt could be as little as $150.
    Toyo does recommend replacing the exhaust if the unit has been in service for a long time. An Exhaust flue pipe costs about $170. You may need to make an adjustment for the different size of the new style flue, depending on how old your stove and flue are.
    Here in
    Alaska a Laser 73 that has not been service a long time can need a lot of parts. If your stove is only used sparingly it may need only limited work. A 19 year old stove will more than likely need a blower motor and a new mat and ring. If it has been running hot for some reason it may need an igniter.
    As you stated, the stove does not owe you anything after 19 years. I would say, rebuild it.
    Keep us posted.
      The L73 is the main house heat with the smaller units, L300 in the mud room in sub 20F cold weather and the L302 in the Kitchen for those -30F nights with a 35 mph wind out of the north! The exhaust is vintage 2007, original unit. When you say blower motor are you talking the back fan or the exhaust blower?
        I'm refering to the exhaust blower motor. The circulating fan motor has much bigger bearings and seems to last a long time.
          Given that your Toyotomi L73 has been reliable for nearly 19 years and only had a significant issue once, a rebuild with new parts might still be a good option if everything else is in decent shape. However, considering the age of the unit and potential internal chimney corrosion, investing in a new, more efficient model could provide long-term savings and advanced features. It might be worth having a professional inspect both your current setup and potential replacement options to make the best choice for your needs and budget.
            I was asked to provide an update so here it is:
            Upon disassembly here was the list of parts I needed with prices from the Internet:
            Burner rebuild kit $255.64
            Flame Rod $33.99
            Igniter $161.04
            Blower Motor $226.58
            Circulation Fan Motor $128.36
            Flue Standard $256.42
            Bent Joint – L
            (stuck and would not release so it was hacksawed off)
            $51.94
            Total
            $1113.97
            At this point I was pushing half the price of a new unit and since the slide controls were getting flakey, I decided 19 yrs was enough and purchased a new 732.
            So, what do I think of the 732 vs the 73? The circulation fan has a distinct hum wheras the 73 was silent except for the bearing ticking indicating a replacement was needed. The warmup/cooldown crackling is far louder than the 73 ever was. Hopefully that will calm down with time. The observed temperature, with the thermister in the exact same place as the 73 reads 2 deg. F low so I compensate by setting the temperature 2 deg. F higher. The Kerosene intake pipe was factory bent for me so my fuel line would not connect. After re-bending, my pipe connected and sealed corrrectly. Hopefully if the loud cracking sounds don't tear the unit apart, I would like to expect a long service life from the 732 like I did the 73.
              Thanks so much for coming back to update us after all these years! It’s rare to see someone follow up like this, and I really appreciate the effort.
              Your comparison between the 73 and the 732 is super insightful, especially for anyone considering an upgrade. Hopefully, the 732 will prove as reliable as your trusty old 73 in the long run. Wishing you smooth operation and no more kerosene intake pipe adventures!
                I do hope the cracking sound is not accompanied with a dull glow from the burn chamber top and heat exchanger? You may need to turn the lights off and turn the heater to the high burn for a little while. The cracking and glow are not a normal part of the Toyo operation.
                Keep us posted.
                ​Tom
                  machinist​,
                  Did you have a chance to look at your new heater to see if it is glowing red on High?
                    At the top of the burn chamber, there is a red glowing ring at the base of the heat exchanger and the center and top of the heat exchanger is glowing red after about 5 minutes of max burn.
