Nortron electric furnace
  • EdP
    • Sep 2011
    • 4
    I have a Nortron Model 21b20 electric furnace. It has started to run steady heat all the time. Tried changing thermostats -did not help. Had to shut it off at the fuse panel. What could be wrong?
    check out the heat limiters as each stage
    • paul52446m
      • Nov 2009
      • 690
      your heat relay is stuck closed. paul
      • LarryHome
        Furnace Repair Installer
        • Sep 2011
        • 33
        I agree, sounds like an issue typically caused by the heat relay. You should inspect it to make sure there's no damage.
        A fool-proof furnace repair manual...
        • EdP
          • Sep 2011
          • 4
          Thank you, Makes sense. I will check that first.
