furnace turns on and runs fine; but very little air seems to come through the registers in the home; anyone know why? blower motor maybe?
15 yo bryant gas furnace
In a central heating and air system if the blower and ducting are sized correctly there should only be a gentle breeze coming out of the ducts. Generally just enough to slightly move a ribbon attached to the fins.
If the system were to blast air into the room as is done with a window AC the result is severe stratification, drafts and uneven heating or cooling.Comment
by hawkins111Toyotomi has dropped the fuel leveler pipe (20475952) for the Laser 56 heater from the inventory. This pipe was set up to include a fire safety valve...
Channel: Toyo Heaters
