15 yo bryant gas furnace
  • itsme8810
    • Oct 2007
    furnace turns on and runs fine; but very little air seems to come through the registers in the home; anyone know why? blower motor maybe?
  • steve t
    • Oct 2007
    • 6
    return air filter stopped up, loose blower belt, inside coil stopped up, bad blower motor, good luck
    • LazyPup
      • Apr 2004
      • 2316
      In a central heating and air system if the blower and ducting are sized correctly there should only be a gentle breeze coming out of the ducts. Generally just enough to slightly move a ribbon attached to the fins.
      If the system were to blast air into the room as is done with a window AC the result is severe stratification, drafts and uneven heating or cooling.
      • itsme8810
        • Oct 2007
        thank you!!
