Our R22-based central A/C has a leaky indoor coil. I have received two estimates for repair. One guy said we can replace just the indoor coil with an R410 coil along with a special metering valve so that it can be used with R-22 refrigerant. The other guy said we have to replace both the indoor coil and outdoor coil/compressor unit so that everything is a new R410 system, for about three times the cost.
I know that an R22 compressor can't run with R410 because of the higher R410 pressures. And I know an R-22 system can't be (practically) partially converted to run on R410 refrigerant because of the incompatibility of lubricants in the coils. But if my existing R22 compressor continues to run on R22 refrigerant, and I simply replace the indoor coil with one made for R410 but metered appropriately to run on R22, will this work? Can I replace only the indoor coil and for now stay on R22 refrigerant (I know... R22 refrigerant is phasing out too)?
Thanks for any insights.
