Toyotomi water heaters and boilers
    • 758
    We are able to help with Toyotomi BS 36, OM 148 and OM 180 water heaters. I do have limited knowledge on the new OM122 and OM 128 heaters. Tom
  • adnadeau
    • Aug 2008
    • 189
    Is it possible to replace the combustion motor bearings in a BS-36UFF-A? Mine sounds a little different than it used to. I saw that a replacement motor was $300+
    Alan
      • 758
      Yes, you can replace the bearings on a BS 36 motor. I don't have the bearing number right handy. The shaft is much bigger than the Laser heater motor, so it is easier to get them off. Don't lose the thrust ring whne you take the motor apart.
      • adnadeau
        • Aug 2008
        • 189
        Thanks for the information. It would be really helpful if you could come up with the bearing number. Otherwise, I'll have to take the motor apart twice; once for the number & again to replace them.
